Quanum Chaotic 3D Quad (P&P
MALTARAUL
#1 Mensaje por MALTARAUL » 29 Ago 2017 18:43
Hola, mi pregunta está relacionada con la compra de un cuadricóptero Quanum Chaotic 3D Quad (P&P de Hobby King, el tema es que viene sin radio, por eso pregunto, mi radio Futaba T6XA de seis canales en FM con su receptor ¿me sirve?
Raúl
PEGASUS
BLUE BABY,
P-51 en foamy
ULTIMATE en foam
BIXLER
los sigo haciendo¡¡¡¡¡Y AHORA LOS REGALO!!!
Re: Quanum Chaotic 3D Quad (P&P
#2 Mensaje por edunimbus » 29 Ago 2017 21:56
Quanum Chaotic 3D Quad (RTF) (Mode 2)
This is Chaotic. What a way to go with this extreme 3D flying quad. There is no telling what you can do with this quad from slow stable (well semi stable) flight to buzzing around upside down for 3D flying with flips and rolls thrown in just for fun of it.
It comes with all the great gear for flying out of the box. The Chaotic is completely fitted out with the Quanum Madcow flight controller driving 2212-1300kv motors, Afro 30A ESC’s and big Gemfan 3D 8” propellers. Orange T-Six 2.4GHz Transmitter with ORX R415X Receiver. Electronics are covered in a vibrant polycarbonate shell for extra protection and easy orientation.
The Madcow flight controller comes preset with three flight modes.
Veal mode: (Stabilized mode) 0 – 100% of the throttle range corresponds to normal motor rotation only. In this mode the multi-rotor will maintain level balance automatically while roll and pitch are centered. The multi-rotor will not flip and roll and the angel of tilt is limited.
Grilling mode: (Acro Stabilized mode) 0% - 100% of the throttle range corresponds to normal motor rotation only. In this mode the multi-rotor will maintain level balance automatically while roll and pitch are centered. The multi-rotor will still flip and roll and the angle of tilt is not limited. This is often called “horizon” or “ratititude” mode but is not capable of inverted flight.
Madcow mode: (3D stabilized mode) 0% - 50% of the throttle range corresponds to reversed motor rotation, 50% - 100% range of the throttle corresponds to normal rotation. In this mode the multi-rotor will maintain level balance automatically while roll and pitch are centered. This is often called “horizon” or “ratittude” mode but with added reversing of motors for inverted flight.
3D flying - the Chaotic way to fly.
Features:
• Tough and light weight carbon fiber frame
• Large 400mm wheelbase
• Quanum Madcow flight controller for 3D flying
• Bi-directional 8” 3D carbon reinforced propellers
• Three stabilization modes – Veal (Stabilized), Grilling (Acro), Madcow (3D)
• OrangeRx T-Six 2.4GHz Transmitter with OrangeRX R415X Receiver
Specs:
Wheelbase: 400mm
Weight: 627g (without battery)
Motor: 2212 1300KV (DJI slot style shaft)
ESC: Afro ESC 30 Amp (SimonK firmware)
Flight Controller: Quanum Madcow 3D
Propellers: Gemfan Bi-directional 8in 3D Carbon Reinforced Propeller set CW/CCW Multirotor (DJI slot style)
Power distribution board: HobbyKing mini PDB with XT60 Connector
Transmitter: OrangeRx T-SIX 2.4GHz DSM 2 compatible 6CH Transmitter – Mode 2
Receiver: OrangeRx 415X
MALTARAUL
#3 Mensaje por MALTARAUL » 30 Ago 2017 08:29
Gracias Alberto, eso lo leí , por eso mi pregunta ¿solamente con 2.4 y orangeR415? no puede configurarse otra radio? por tu respuesta entiendo que no
PEGASUS
BLUE BABY,
P-51 en foamy
ULTIMATE en foam
BIXLER
#4 Mensaje por edunimbus » 30 Ago 2017 20:49
Hola Raúl
claro, el PP viene sin TX. Le vá cualquiera a partir de 5/6 canales según acabo de ver.
Si tenes futaba FM, perfecto.
La única precaución es asegurarse que nadie te prenda otro equipo en la misma frecuencia, como sabrás, cosa que con la nueva tecnología 2.4 no sucede.
En caso de ir agregando comandos como gimbal para camara u otros chiches si estarías necesitando mas canales pero no parece ser el espíritu de este multicóptero.
